interface-config-radio-instance
Applies an association ACL policy and a radio QoS policy on this radio interface
An association ACL is a policy-based ACL that either prevents or allows wireless clients from connecting to a controller managed access point radio. An ACL is a sequential collection of permit and deny conditions that apply to controller packets. When a packet is received on an interface, the controller compares the fields in the packet against any applied ACLs to verify the packet has the required permissions to be forwarded, based on the criteria specified in the access lists. If a packet does not meet any of the criteria specified in the ACL, the packet is dropped.
use [association-acl-policy|radio-qos-policy]
use [association-acl-policy <ASSOC-ACL-POLICY-NAME>|radio-qos-policy <RADIO-QOS-POLICY-NAME>]
| use | Applies an association ACL policy and a radio QoS policy on this radio interface |
| association-acl-policy | Uses a specified
                        association ACL policy with this radio interface
| radio-qos-policy | Uses a specified
                        radio QoS policy with this radio interface
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#use association-acl-policy test nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context interface radio1 rf-mode sensor placement outdoor mesh client rts-threshold 100 off-channel-scan channel-list 2.4GHz 1 guard-interval long aggregation ampdu tx-only rifs tx-only use association-acl-policy test sniffer-redirect omnipeek 172.16.10.1 channel 1 aeroscout forward ekahau forward ip 172.16.10.1 port 3 --More-- nx9500-6C8809(config-profile-510TestProfile-if-radio1)#
| no (radio-interface-config-command) | Dissociates the specified association ACL policy and radio QoS policy |
